Farmall M Belt pulley
Zach Bouchard
02-14-2008 20:11:45
Is it hard to replace the M belt pulley seal? If my pulley only drips a bit, is it worth fixing?What is the best way to clean the gear case of a belt pulley out? Someone shoved a paper towel in the bottom when it was off. I pulled one of the paper towels out but didn't see the other becasue it was shoved so far in. So now I have oil mixed with paper towel. I was thinking off running diesel through it and then refilling it.
Wayne in MN
02-14-2008 20:25:30
 Re: Farmall M Belt pulley in reply to Zach Bouchard, 02-14-2008 20:11:45
Remove the pulley unit to clean. It is lubed from the transmission so attempting to clean with diesel will mix with the transmission oil. The seal can be removed without removing the entire unit. Remove the cap screws & tap on the backside of the pulley flange. Remove the capscrew on the end of the shaft & slide the parts off. Reverse proceedure for installation. I like to use a VERY thin application of silicone sealer on the metal shims when re-assembling.
