rear axel leaking
Lucien Cyr
02-16-2008 04:27:12
I put new seal on the rear axel on my 1948 Cub and it still is leaking oil. There was a small grouve on the axels, so I put a shim to try to move the seal from that grouve. Is there an other way. Both wheel leak, byt the right side is worst. Merci
JT
02-16-2008 06:02:52
 Re: rear axel leaking in reply to Lucien Cyr, 02-16-2008 04:27:12
Put a Speedi-sleeve on the axles where the groove is at.
Jim
Kristof
02-16-2008 04:38:57
Put sleeves over your axles, that should work.
