fireworks to smoooooth running
tooltime
02-16-2008 13:57:56
today i replaced bad 6volt coil with a 12 volt coil from napa store, then i got rid of ballast resistor., i doulbe checked all wiring on tractor with schematic in hand ( THANKS BOB for the diagram) Then, i fired tractor right up, adjusted carb a bit, she runs very nice. thanks for all your help, Jim
james rumph
02-17-2008 05:08:47
 Re: fireworks to smoooooth running in reply to tooltime, 02-16-2008 13:57:56
Put a ballest res back on ! It keeps the coil from over heating . It does not effect performance at all. It drops voltage going out to keep you coil cool . Run the tractor for awhile and feel the temp of the coil it will be hot . If you for some reason pull the ign switch on to do a test or it stalls with the switch on and it not running it will burn the coil up and cook the points and cond .
Trust me on this i learned this the hard way ! It took about 4 mins and the brand new electronic ign was toast.
If you bought a "12v tractor coil" then the resister is built in . "But" if it is just a 12v auto coil it is NOT and you need to add one .
If your not sure how to install one i will help you . Just check it all out before you get a fire like i did . I got this same talk from the I.H dealer .
tooltime
02-17-2008 06:34:54
 Re: fireworks to smoooooth running in reply to james rumph, 02-17-2008 05:08:47
the coil i bought from napa , was the kind that does not require a external resistor. so i got rid of ballast resistor. coil gets a little warm , but not hot. thanks, Jim
Janicholson
02-16-2008 15:57:35
Jim, I knew it was just minor things. Thanks for sticking with it. JimN
tooltime
02-16-2008 18:49:53
 Re: fireworks to smoooooth running in reply to Janicholson, 02-16-2008 15:57:35
THANKS FOR ALL YOUR HELP, I COULD NOT GET THROUGH ALL THIS WITHOUT THE HELP I RECIEVE FROM YOU ALL, THANKS AGAIN, jIM
