560 Diesel????
Redsm
02-16-2008 21:04:21
I recently Found a 560D for sale, does not have T/A, T/A less from factory, Good runner, Standord drawbar, Hyd's work encluding power steering, tires on back 20% remaining, 3354 Hrs, Tach works, BAD starter.
Tractor looks as if it has been barn kept and took pretty good care of as their are some noticable things that have been done to show.
Tractor has factory paint, Name tags look very good(Factory) but hood is farely faded. Sheet metal or "tin" is in very good shape.
The owner wants $1500 for it, Is this a good price or not to good??? I did not know anything bout pricing because of the drawbar or "hitch", and starter.
Any help is Appriciated, Thanks
Janicholson
02-17-2008 05:26:28
 Re: 560 Diesel???? in reply to Redsm, 02-16-2008 21:04:21
You bet in all ways. If it is pull startable, it very good. JimN
Up North Louie
02-17-2008 02:53:07
If I were there, and it ran, I'd be buying. I love my 560, but it's a gasser and I'm looking for a diesel. $1500 is a great price, regardless of your intentions, working, restoration, whatever.
Don
gmd
02-16-2008 21:44:25
"IF" it will start and Run Well, I would say take it and run. If you cant get it to run, make it start somehow and then if it operates well take it and run.
Jimmy King
02-17-2008 16:46:13
 Re: 560 Diesel???? in reply to gmd, 02-16-2008 21:44:25
Good Starter, good batterys, good glow plugs and it will be a good starter if the engine is in decient shape. You will have to use the glow plugs if it is 100 degrees out and if it has been shut off for more that 15 minutes.
