Touch control cylinder head removal - or not?
tractorsam
02-17-2008 15:33:03
I'm in the middle of attempting to rebuild a touch control unit on a Super C. Despite being about as brutal as I think I can without causing too much damage I cannot get the cylinder head to come off. Is there a trick or is it just well stuck after 50+ years? Many thanks, tractorsam
P and R Pete
02-17-2008 18:43:13
 Re: Touch control cylinder head removal - or not? in reply to tractorsam, 02-17-2008 15:33:03
LOL, I just lifted mine off my Super-A about an hour ago. A 1949.
I can see what my first problem will be!
I don't even use it. I'm just tired of it leaking all over the torque tube.
Start another thread about how it goes, since you're a couple days ahead of me, about problems, tricks, tips, whatever. Be better info than any manual!
CNKS
02-17-2008 19:47:39
 Re: Touch control cylinder head removal - or not? in reply to P and R Pete, 02-17-2008 18:43:13
There really aren't any tricks, and if you are putting a kit in, you do need a diagram unless you have a photographic memory. Keep everything clean and lay out the old parts in order, that and the diagram will prevent any problems. Too many similarities among the orings, etc.
CNKS
02-17-2008 17:05:20
Take a rigid paint scraper and carefully drive it in a little at a time in several places. Make sure there are no burrs on the edge to dig into the metal. It will come off -- I had the same problem as you. Don't use a screw driver except as the final step once it starts to move.
tractorsam
02-17-2008 17:53:47
 Re: Touch control cylinder head removal - or not? in reply to CNKS, 02-17-2008 17:05:20
Thanks for the info. Pretty sure there weren't any hidden fastners but I've been down that road before. I've tried driving a scraper in already but I'll give it another go tomorrow. After 50 years it sure is stuck on there tight. Many thanks, tractorsam
ScottyHOMEy
02-17-2008 18:49:22
 Re: Touch control cylinder head removal - or not? in reply to tractorsam, 02-17-2008 17:53:47
Mine came off hard, too. Only other thing I'll throw in is the gasket on mine stayed together and looked just like iron. It'll come off hard, too.
TWheat
02-17-2008 16:02:24
I forget the ft# to torque it down, somethin like 75#s so add to that 50 years of it stickin together, yep, it can be a bear to get loose. I just kept tappin it and finally got a blade between the 2 parts. Take it slow and easy, it will come off.
