1950 Farmall Super A wont start
stan w mckaskle
02-17-2008 16:11:26
Guys, i have a 1950 suprA that i just bought. The man said that it was running 1 year ago. cleaned it up and it wont start. turns over good, gets good gas but i dont seem to be getting spark, tryed plug in plug wire and held next to block and no spark . any ideas???? also gaps are set correctly and tractor has been converted to 12 volt. PLeeezzze????
El Toro
02-17-2008 18:22:54
 Re: 1950 Farmall Super A wont start in reply to stan w mckaskle, 02-17-2008 16:11:26
Take a small piece of 320 wet or dry and clean those points, then see if the engine will start.
Hal
Dave_Id
02-17-2008 17:48:32
Slap in a new set of points and condensor. New plugs couldn't hurt either.
stan w mckaskle
02-17-2008 16:25:44
yeah its got a distributor. checked all connections and cleand all contacts. still nuthin.
old
02-17-2008 16:31:03
 Re: 1950 Farmall Super A wont start in reply to stan w mckaskle, 02-17-2008 16:25:44
Remove the cap, rotor and dust cover if it has one. Turn the switch on and then by hand open and close the points. You should get a spark when you do that. If you don't run a hot wire to the coil and try again. If you get a spark when hot wired then you have a switch problem etc going back from the coil if you still don't have spark replace the points and try again
Bob
02-17-2008 16:19:24
Distributor, right?
Have you cleaned the points?
steve from mo - dangit!
02-17-2008 16:18:25
Start from the battery and go to the spark plugs, checking for proper voltage at each step. A multimeter is good for this.
