b250 hydraulics
buggsy
02-17-2008 20:01:22
thanks for prior help
b250 3 pth wont stay up as soon as i let go of lever it falls, fluid level is full
buggsy
JimB2
02-18-2008 09:17:00
 Re: b250 hydraulics in reply to buggsy, 02-17-2008 20:01:22
Hi Buggsy, does your 250 have the old style 3pt hydraulic control lever which has 3 position lift, hold and drop? If so try the following test, lift the 3pt implement and close the isolation valve (which is the T handle valve in front of the seat), let 3 pt control lever back to hold position, if 3 pt arms go down then the lift cylinder is probably leaking. If 3 pt arms stay up then problem is in 3 pt control lever, possibly the hold position of the control lever is not adjusted properly.
JimB
buggsy
02-18-2008 16:20:07
 Re: b250 hydraulics in reply to JimB2, 02-18-2008 09:17:00
thanks jim
my problem is in the control lever, now any ideas of how to adjust it
thanks
FromJB2
02-18-2008 18:19:32
 Re: b250 hydraulics in reply to buggsy, 02-18-2008 16:20:07
Hi, I have a B414 Operators Manual with a section on the old style 3pt hydraulic controls.
Tomorrow, I can scan and email you the appropriate pages.
JimB
