h 12 volt
ronnie woodruff
02-18-2008 13:16:09
tryed putting a chevy alternator on my h when i hook up the main wire it arcs and heats up this was a 1 wire alt. tried with a standard alt. and had same issue anyone have any ideas
Jossette
02-18-2008 17:41:59
 Re: h 12 volt in reply to ronnie woodruff, 02-18-2008 13:16:09
third party image
dfg
ronnie woodruff
02-18-2008 14:58:10
do i just change the cabels around and will the starter still work
Bob M
02-18-2008 18:21:31
 Re: h 12 volt in reply to ronnie woodruff, 02-18-2008 14:58:10
The starter will work fine grounded either polarity. But when switching to negative ground you'll need to swap the wires at the ammeter - otherwise it'll read "backward".
ronnie woodruff
02-18-2008 14:58:04
old
02-18-2008 14:25:08
As Bob said. If you still have it + ground it will do just that can fry the alternator the moment you hook it up. You have to switch it to - ground or it will never work
Bob M
02-18-2008 13:33:06
Is per chance the the battery connected with the positive post grounded? If so it'll spark exactly as you describe when you connect the main wire.
Also there's a good chance you toasted both alternators the instant you got sparks.
