Will 6 volt lights work on 12 volt system
Bill thompson
02-18-2008 14:19:39
Dumb Question. Can you use 6 volt lights on a converted 12 volt system?
mark
02-18-2008 18:30:49
 Re: Will 6 volt lights work on 12 volt system in reply to Bill thompson, 02-18-2008 14:19:39
Yeah...for about 2 seconds.
Jossette
02-18-2008 17:39:14
you could hook them in series and they would work
---2 per curcuit.
ArleninOr
02-18-2008 15:21:38
As long as it takes to say POOF !!
Bill thompson
02-18-2008 14:57:31
Thanks Bill
r4etired
02-18-2008 14:38:06
The number I think is 1033,that is the 12 volt bulb with a 1157 base.Where I live they are hard to get,when John Deere had them, they were 6 bucks each.
RustyFarmall
02-18-2008 17:40:33
 Re: Will 6 volt lights work on 12 volt system in reply to r4etired, 02-18-2008 14:38:06
I've got the 1133 6 volt bulbs, and I found where I can get a bulk lot of the 12 volt bulbs. Guess I oughta get some.
old
02-18-2008 14:28:58
Yep for about 5 seconds and then they blow. Yes you could wire them up in series but that never works well because if you loose one the other one will not work.
Allan In NE
02-18-2008 14:23:58
They work really, really well for a really, really short time. :>)
Allan
Hugh MacKay
02-18-2008 15:34:13
 Re: Will 6 volt lights work on 12 volt system in reply to Allan In NE, 02-18-2008 14:23:58
Allan: Bout 20 seconds, I hooked one up by mistake couple weeks back.
Allan In NE
02-18-2008 15:37:03
 Re: Will 6 volt lights work on 12 volt system in reply to Hugh MacKay, 02-18-2008 15:34:13
Gawd awful bright, wasn't it? :>)
Allan
Hugh MacKay
02-18-2008 16:23:46
 Re: Will 6 volt lights work on 12 volt system in reply to Allan In NE, 02-18-2008 15:37:03
Allan: Got a dozen or so sealed beams here, picked them up at an auction for 50 cents for the whole box, and they fit my 130 and 140, both 12 volt. Problem is they are not marked 6 or 12, however there are some of each. I thought I had them sorted trying on my 6 volt SA. I was having some light grounding problems decided to try what I though was a 12 volt in 140 tail light. Being confident I went to check headlights after turning them on. Got to the front, looked back and my shop door was lit up like town hall on spotlight side. I didn't make it to the switch.
Bob
02-18-2008 14:28:40
 You're a BRIGHT one, Allan! in reply to Allan In NE, 02-18-2008 14:23:58
Bill, IF they are sealed beams with two terminals, some folks have run a wire accross to the other side of the tractor, and connected them in series. Of course, you could use the appropriate resistor, as well, but at that point, why not just swap out the bulbs?
