farmall m manifold studs
lbm
02-18-2008 17:12:47
would anyone be able to tell me the size and lenghts of the manifold studs for a m. thanks
Red Mist
02-19-2008 07:07:17
 Re: farmall m manifold studs in reply to lbm, 02-18-2008 17:12:47
John, Andy and Tractorman are all correct. They are, indeed, coarse threads on one side and fine threads on the other end.
The 7/16" (2.25" long), started with M serial number 41346 - part number 63459D.
From serial number 501 thru 41345, they were 3/8" - part number 45223DA.
Both showing still available from your friendly Case/IH dealer. mike
John M
02-19-2008 03:08:18
I think it was 2 1/4" course on the head side, fine on the manifold side. I have a couple at work, of all places, Ill check.
TractormanNC
02-18-2008 18:47:40
Can't help you on the length, but be aware that the early ones used 3/8 dia. studs and the later ones used 7/16. Don't know the S/N break on this. HTH.
