MTA problem
Mike Songstad
02-19-2008 16:41:52
Hello, my Super M-TA started running rough about a week ago, like it"s running out of gas. It only does it when the engine is warm. I snugged up the bolts on the intake manifold & it worked fine yesterday, but I had to push some show today & it started doing it again. I can keep it running somewhat if I fiddle with the choke. Actually, as I drove it into the shed tonite, the choke was all the way on. My fuel is good, the filter is clean, Spark plugs are good. Carb is clean. Any ideas what else I should look for?
Thanks in advance, Mike
sod
02-21-2008 07:32:04
 Re: MTA problem in reply to Mike Songstad, 02-19-2008 16:41:52
check in the top of the sediment bowl where it goes into the tank. rust will plug that I fastened a tiny roll of aluminum screen to the top of the sed bowl and it has never done it again
good luck
sod
Mike Songstad
02-20-2008 20:03:38
OK, thanks for all the replies. I'm thinking it's a vacuum leak too. Like I mentioned, I snugged up the manifold bolts & it ran fine, til I used it again the next day. Maybe just a fluke? I suppose it could be a bad gasket there. I did check the screen at the end of the fuel line & that was fine.
Thanks again, I'll keep playing around with it.
Mike
BillyinStoughton
02-20-2008 12:26:03
I think Allen may be barking up the right tree. Most of the older Farmall's (mine included H, M, 400) like almost NO choke at all (I started them all last weekend when it was -8). Check for a vacuum leak either at the manifold or possibly at the carb flange.
Good luck!
Billy
Jay Kay
02-19-2008 21:50:28
If the other suggestions don't help check the manifold gasket and the manifold itself
Keith in Iowa
02-19-2008 19:59:02
Did you unhook your fuel line at the carb and remove the fitting going into the carb? There should be a screen in there. It might need cleaning.
Richard Wurtzberger
02-19-2008 17:30:32
My dads 53 super m had simimlar problems. A piece of a fabric/ metal hose got in the tank and got caught in the sediment bowl housing.plugging the line.
ejr-IA
02-19-2008 17:25:31
Check float level in carb too.
Allan In NE
02-19-2008 16:44:17
As a general rule, Farmalls don't like a heck of a lot of choke, so if your tractor even runs with the choke all the way on, you've got to have a vacumn leak somewhere.
Allan
Bellyacre
02-19-2008 17:17:57
 Re: MTA problem in reply to Allan In NE, 02-19-2008 16:44:17
Gas cap vented? Check fuel flow for at least 30 seconds?
