Farmall H LP
Zach16
02-20-2008 08:52:53
Thanks for the replys on the stuck question. so now i have an other ? how hard is it to convert the LP into Gas?? Zach
Zach_16
02-20-2008 11:50:30
 Re: Farmall H LP in reply to Zach16, 02-20-2008 08:52:53
thanks but what about the intake and exhaust manafold. and the only gas tank that we have is a M tank. thanks Zach
D Slater
02-20-2008 13:03:35
 Re: Farmall H LP in reply to Zach_16, 02-20-2008 11:50:30
Its a conversion to LP to start with so shouldn't be hard to change back, you need to figure out what parts are changed for the LP and replace them with the parts for a gasoline tractor. Conversions were done several ways, some kept the gas carburetor and manifold on tractor and some changed both or left the manifold and replaced carburetor. Hood or air cleaner may or may not be modified also.
Andrew Z
02-20-2008 09:32:44
Not hard just need a gas tank and fuel line, and a carb. Outside of that you should be good to go.
Andrew
