Mounted single bottom plow on Super H
VA Gasman
02-22-2008 05:17:16
Years ago I had someone give me a nice single 16" bottom plow. I was told that it had been used on a H. I looked at it yesterday and believe that with the drawbar removed it will may be able to match up. Does any one know if there was a single bottom mounted plow for H ?
whiskeydented
02-24-2008 17:52:36
 Re: Mounted single bottom plow on Super H in reply to VA Gasman, 02-22-2008 05:17:16
Hi,
I have a 2 way mounted plow on an h it shoudn't be too much different. I'm going to try to post a couple of photos for you.
Mike
third party image
third party image
gene bender
02-22-2008 06:01:33
Model H-190 was built from46-54 and yes the drawbar is removed
VA Gasman
02-22-2008 10:02:21
 Re: Mounted single bottom plow on Super H in reply to gene bender, 02-22-2008 06:01:33
Is there a site where i could see a photo or drawing of One? I wonder if something is missing with this plow.
Thanks
gene bender
02-22-2008 11:45:00
 Re: Mounted single bottom plow on Super H in reply to VA Gasman, 02-22-2008 10:02:21
I have access to the parts book for that plow and you should go to a dealer and see if he cant get the owners manual for it then you would have all the info. Someone who sells manuals that are original would probably have one also as there are vendors who have that stuff. I have lots of manuals for the different stuff i have for my As and the Bs. later gene b
