Super A valve cover gasket thickness
SteveNH
02-22-2008 10:14:12
I need to make a new valve cover gasket - what thickness cork should I use? I have both 1/16 and 1/8. The one that came off looked thick.
Thanks.
K-Mo
02-23-2008 04:34:34
 Re: Super A valve cover gasket thickness in reply to SteveNH, 02-22-2008 10:14:12
Unless you enjoy the challenge of making your own, you can buy gaskets from NAPA or O'Reillys for less than $10.
K-Mo
SteveNH
02-24-2008 06:12:29
 Re: Super A valve cover gasket thickness in reply to K-Mo, 02-23-2008 04:34:34
Unless I have a part number the Napa around here doesn"t want to help you... The only thing I can get from there is aggravated.
TractormanNC
02-22-2008 10:37:43
I would use 1/8. That's about what the originals were.
