Combine engine in 806 gas
matthies
02-22-2008 18:27:15
Could anybody tell me if any combine gas engines are the same as an 806 gas engine? Just want to put a gas engine back in. thanks chris
ejr-Ia.
02-23-2008 14:11:06
 Re: Combine engine in 806 gas in reply to matthies, 02-22-2008 18:27:15
Yes the 715 used the 301 gas engine.
Owen Aaland
02-23-2008 00:41:26
You will need to change the front cover and the plate between the front cover and block. The rear holes in the block are most likely not threaded like the tractors so you will need longer bolts to use with nuts to mount the rear plate. You will also want to replace the oil pan and valve cover.
Janicholson
02-22-2008 21:44:11
There may be components that need to be swapped. The crank may or may not need pilot drilling to accomodate the shaft tip. Front cover may be different as well. There mkay be some that have no sleeves (running sleeveless). if it is good it just means the next rebuild will need mqachine work. These factors may not all apply, but caution is needed. JimN
Bill Lisbon
02-22-2008 18:45:53
I think a 715 combine used a 301 gas.
