Need new engine on my F-20
Farmallb
02-23-2008 07:11:38
Wondering if finding one is viable, and if so what coul I expect to pay for one. Mine is nearly stuck, manifold bad, block filled up with rust, ect
El Toro
02-23-2008 16:34:03
 Re: Need new engine on my F-20 in reply to Farmallb, 02-23-2008 07:11:38
Pour ATF on top of the pistons and let them soak.
You can use a piece of 2X2 oak and a hammer and drive the rods and pistons out. The sleeves may come out with them. Take your time and don't too wild with the hammer. Hal
James Williams
02-23-2008 11:16:18
Ive never seen a bad F20 block,Ive broke a manny of them loose,Hone them out,Adjust the shims and install new rings,Email me if you need help
jimmy
J.J. from Afton
02-23-2008 07:38:11
You'd be amazed how well those old blocks will clean up. Its always worth a try with that one first.
F-Dean
02-23-2008 07:24:14
Other than that, what's wrong with it?
louis j waite
02-23-2008 16:33:19
 Re: Need new engine on my F-20 in reply to F-Dean, 02-23-2008 07:24:14
looking for a pressure plate fo f20
Scott Rukke
02-23-2008 19:52:59
 Re: Need new engine on my F-20 in reply to louis j waite, 02-23-2008 16:33:19
There's a couple on Ebay.
