eaton power steering pumps
glennster
02-23-2008 07:31:06
found this on the web about the eaton pump like allan used on his m. looks like they came on 1958-1967 ford products.
bc
02-24-2008 00:00:20
 Re: eaton power steering pumps in reply to glennster, 02-23-2008 07:31:06
Eaton & Cessna. Years ago Cessna aircraft company of Wichita, KS also had a hydraulic manufacturing company in Hutchinson, KS. I knew a lot of people that worked there and worked there a while as a kid myself. Cessna made pumps and valves, etc. and most of them were for the farm industry. Cessna closed down their hydraulic manf. and Eaton bought them out. The Hutch plant then became the Eaton plant making hydraulics but had less that half the work force that Cessna carried. If you see anything made new by Cessna then chances are it is actual Eaton made. I believe Eaton closed the Hutch plant a few years ago.
Paul G. in Mn
02-23-2008 10:42:41
what did you use for the bracket to mount the pump to the govener cover? how about the pully's? I have a charlyn pump but its missing the bracket and pully.
Allan In NE
02-23-2008 10:48:54
 Re: eaton power steering pumps in reply to Paul G. in Mn, 02-23-2008 10:42:41
Guess you're talking to me?
This is the Charlynn setup for pre-SH/SM tractors. They went to the pump on the generator belt later and that took a totally different bracket.
Mine came off a salvage M tractor.
Allan
Paul G. in Mn
02-23-2008 10:53:38
 Re: eaton power steering pumps in reply to Allan In NE, 02-23-2008 10:48:54
ok...wasnt sure if they used this eaton pump on that setup or something different....the one I have must be an eaton then too. thanks Paul
Allan In NE
02-23-2008 07:55:37
Yep,
They came on everything from Pintos to Thundrbirds to F-700 grain trucks. Anything that has a remote tank has probably got this same pump.
Allan
glennster
02-23-2008 07:37:38
here is a link to napa parts online. they have the pump for abut 104.00, there is a core charge
