antifreeze
Tony S.
02-23-2008 13:36:08
Do you generally put antifreeze in the old Farmalls with no water pump?
Don L C
02-23-2008 17:17:04
 Re: antifreeze in reply to Tony S., 02-23-2008 13:36:08
You need a mixture of 1/2 anti-freese and the ouher 1/2 water....
Tony S.
02-23-2008 16:31:11
The reason I ask is that as I understand it, these old non pressurized systems depended somewhat on evaporation for their cooling. You would have to add water every day Just wondered if antifreeze might affect the evaporation .
Tony S.
02-23-2008 16:32:07
 Re: antifreeze in reply to Tony S., 02-23-2008 16:31:11
Not that I plan to work the tractor very hard.
Janicholson
02-23-2008 16:39:35
 Re: antifreeze in reply to Tony S., 02-23-2008 16:32:07
They do not evaporate to cool. The radiator removes drastic amounts of heat, cooling the Coolant, so it sinks to the bottom and enters the block. ThermoSiphon. The old timers used alcohol in the water to prevent freezing. It did evaporate, but not because it was intended to, but that it was unavoidable. Put 50/50 mix in it and keep down corrosion. no problem. JimN
sdscooter
02-23-2008 14:14:13
sorry,but shiould also be noted that having antifreeze,in the proper mixture,50/50%,will also help keep your tractor from overheating and adds corrosion protection.
John M
02-23-2008 14:05:42
You need to premix it before you put it in since it wont circualte as well as a waterpump would.
sdscooter
02-23-2008 13:56:54
if you live in an area where you have freezing weather, you will need antifreeze. water pump or not.
