diff lock stuck
more Ron
02-24-2008 09:17:54
I have an international 454/2400 and the diff lock is stuck in
in the past I used a tire lever and applied a bit of pressure inder the pedal and rocked the tracktor and it poped out. this time no luck
I had been working it hard pulling logs.
I have tried running it straight back and forwards and even jacking up one wheel and racking it back and forward. but its still stuck in
help
JimB2
02-24-2008 13:40:40
 Re: diff lock stuck in reply to more Ron, 02-24-2008 09:17:54
Hi Ron, I saved suggestions by Bernard from Quebec as he has worked on many of these models as a mechanic at CIH. Here is his Diff Lock reply:
Differential Lock:
If the differential lock is stuck locked or it doesn't lock. Check the pedal for free movement, it has a shaft that actuates the lock fork, the shaft is below the hitch cover and the link from the pedal hooks on it. Often it has rust on the shaft where it turns in the rear housing. Try to spray a good lube on the shaft or you may have to lift the cover and remove the shaft and clean it.
Bernard le mécano Québec Canada
Usually you can release the Diff lock by driving slowly in a straight line, lift up on the foot pedal and tap the left brake pedal then the right brake pedal enough to make the brake grab.
Hope this helps
JimB
