farmall b fuel line
rytre
02-24-2008 13:22:55
Is there a company out there in which I can get an exact duplicate gas line from for my farmall b? also did the farmall b ever come with a marvel schebler carb? if so what was the model number? thanks in advance
Tom Fleming
02-27-2008 16:06:05
 Re: farmall b fuel line in reply to rytre, 02-24-2008 13:22:55
I too am a big fan of copper. No rust, takes vibration a bit better, and easier to work.
Now, the question is, how original do you want to get?
kippster
02-27-2008 06:12:39
I always made them out of copper. It was easier to flare and the brass fittings would strip out before you fouled up the threads on the sediment bowl or the inlet for the carb. Just my two cents.
ihc49er#2
02-24-2008 19:33:46
rubber lines look gross and sloppy and are not original.thats my opinion.
RustyFarmall
02-24-2008 16:48:45
Yes. I've got those steel lines in my e-crater store. Link
Harold H
02-24-2008 16:46:54
You can buy original from OEM or can use a steel brake line by putting a vibration loop in it and it looks just like original.
Harold H
El Toro
02-24-2008 16:17:21
third party image
A fuel line like this will take the vibration and is easy to makeup and install. Hal
Dave H (MI)
02-24-2008 14:49:04
You can make one out of brake line. Search under my handle for posts last summer regarding my attempts to replace the gas line on our B. There should be a number of them. I don't like the rubber ones and everyone said not to use copper. Read my archives....lots of good stuff.
gene bender
02-24-2008 14:14:22
I have them most are rubber hoses but mine are the steel ones.
CNKS
02-24-2008 13:46:07
The answer to your second question is yes. Part # is in the parts manual, or look at the online manuals on caseih.com.
glennster
02-24-2008 13:37:45
oem tractor parts has the original type fuel lines. oem tractor parts dot com.
