charlin powerstering
Mike L
02-24-2008 13:53:40
I have a Farmal M just aquired a
charlin power stering box. How does it fit on
the tractor?
Chad Lorson
02-28-2008 07:55:13
 Re: charlin powerstering in reply to Mike L, 02-24-2008 13:53:40
you have to cut the steering shaft and connect it, then u need a pump which runs off the motor. it is much easier if u have live hydrolics because u can hook it right up without needing the pump mounted under the hood
Red Mist
02-24-2008 16:25:15
Gene's suggestion is the best way, but there is a manual for sale on ebay right now. Just type in "Farmall power steering" and it will come up.
mike
gene bender
02-24-2008 14:16:18
Your best way would be to e-mail CHAR-LYNN and get the instructions and manual
