Farmall 130
junkmanduff
02-24-2008 16:51:17
Have a Farmall 130 that has worked fine, Changed governor spring but could not get as heavy a one as original. It worked fine for a week, started dying under load. Will sit an idle all day, plowed snow today by working throttle.Checked carberator though it might be froze but seemed o.k. Plugs fine. Could it be dirt or is it the governor.
tn terry t
02-28-2008 05:41:04
 Re: Farmall 130 in reply to DHB, 02-24-2008 16:51:17
tn terry t said: (quoted from post at 06:33:12 02/28/08)
junkmanduff said: (quoted from post at 05:42:50 02/28/08) You guys are a wealth of information!!!!Was wondering what is the best thing to use to clean a carburator.Some of my spark plug wires are shot,can i rob off something else,make them my self, or should i spring for a new set.
Thanks
berrymans carb.dip works pretty good as for the plugs i aint figured how to make those yet :shock: champion d-16 autolite 386
in sorry i mis read what you wrote i absoulutly would not get the wires from tsc junky plasticly crap i like the soild copper wire core myself
tn terry t
02-28-2008 05:33:12
 Re: Farmall 130 in reply to Allan In NE, 02-24-2008 16:51:17
Thanks
ihc49er#2
02-24-2008 19:27:34
 Re: Farmall 130 in reply to junkmanduff, 02-24-2008 16:51:17
if you have a weak spring in governor it will not work as should, be lazy and no zip.
CNKS
02-24-2008 16:54:14
Sounds like a fuel flow problem to me, and the carb could stand a good cleaning.
