F656 D HS
wolfe in tx
02-24-2008 21:02:05
Bought a F656 IH today it blowed a hyd line under the rad. Blowed oil 20 ft. stopped fixed hose and refilled hyd oil. Have no hyd steering breaks will not pull itself. Is there some thing to bleed or adjust. Please help Thank You wolfe
Steven f/AZ
02-25-2008 06:28:31
 Re: F656 D HS in reply to wolfe in tx, 02-24-2008 21:02:05
I bet OPEC loves that picture, Allan. :lol:
Allan In NE
02-25-2008 03:59:39
Same thing happened to me a couple of years ago.
That tractor will hold all of 18 gallons of oil. Did you replace the filters too?
If the front pump is a little on the weak side, it might take a while to get all the air out of the system.
Don't think I'd even try to move it until the steering works insuring you have adequate oil to the charge pump also.
Just keep working that power steering until it takes a prime and then see if it will move.
Allan
third party image
Larry NCKS
02-25-2008 01:12:56
 Re: F656 D HS in reply to El Toro, 02-24-2008 21:02:05
wolfe in tx said: (quoted from post at 00:02:05 02/25/08) Bought a F656 IH today it blowed a hyd line under the rad. Blowed oil 20 ft. stopped fixed hose and refilled hyd oil. Have no hyd steering breaks will not pull itself. Is there some thing to bleed or adjust. Please help Thank You wolfe
"Have no hyd steering breaks will not pull itself." might help if you rewrite this line plainly. I'm not sure what all you are saying here. Brakes have nothing to do with hydraulics on this tractor, nor does the lack of engine power. The steering does not need to be bled out.
Harvey Mohr
02-25-2008 10:05:26
 Re: F656 D HS in reply to Larry NCKS, 02-25-2008 01:12:56
You have an air lock turn steering wheel back and forth may have to jack up front wheels
edward_m
02-25-2008 09:57:01
I too am confused by that statement.....almost sounds like pump, but I didn't think a 656 came out with Hyd brakes: I know a 756 did, 'cause I had to replace a pump in one.
