What is a Farmall 400 Diesel worth???
MartinD
02-25-2008 04:30:44
Going to look at a 400 Diesel this weekend.Guy says it doesnt run but does spin over and has compression.He is asking $950.What yall think??Thanks
Chad Lorson
02-28-2008 07:52:48
 Re: What is a Farmall 400 Diesel worth??? in reply to MartinD, 02-25-2008 04:30:44
that is a very reasonable price but if u have to overhaul the motor it can become quite pricy. i have about 5K in my mdta for justthe motor
r4etired
02-25-2008 17:49:37
My neighbor told me he could have bought a real nice 560 for what the head, block,pump and valve operating linkage cost on a 400 diesel he bought to run an auger
nebraska kirk
02-25-2008 06:22:12
I would say go for it! You could ask if he would take any less, but if not, pay what he asks. I believe it was georgeKY that bought a 400D for $800?, it was loose and not running. He got it running within the hour IIRC.
Janicholson
02-25-2008 06:19:51
 Re: What is a Farmall 400 Diesel worth??? in reply to Kevin (FL), 02-25-2008 04:30:44
MartinD said: (quoted from post at 13:30:44 02/25/08) Going to look at a 400 Diesel this weekend.Guy says it doesnt run but does spin over and has compression.He is asking $950.What yall think??Thanks
The amount with pretty usable tires and fair tin would be OK. If either are poor, it is high. If the Gas side compression is very even between cylinders, at least it has possibilities. If divergent more than 15% or so I think it is 300 high. It may be simple, or complex & expensive to make right. Gamble is best done with a low investment. JimN
