behlens power steering
756puller
02-25-2008 10:05:50
have a couple of 450s with loaders on them, opened up the front steering gear and put some oil in there and it helped a little had, had one that I worked the outside lever on the tractor hydrolics and the power steering seemed to start to work so my question is what can you do to check the pump flow and to make the power steeriing work better?
Armand Tatro
02-25-2008 12:25:40
 Re: behlens power steering in reply to 756puller, 02-25-2008 10:05:50
If you are using main hyd. pump for both P>S> and other hyd. uses the valve that diverts 2or 3 gpm to power steering is not working. Best fix would be to mount a belt driven pump from the crank shaft to supply P.S. Maybe Allan neb. will come in with an explanation and pictures of what he did on his M. Scroll thru until you find his post on PS. Pump wise what he did for char-lynn would be same for Behlyn PS.
