sandblasting price
Pat-CT
02-25-2008 13:43:55
how much would it cost to have my h totaly sandblasted...i have no clue about this type of thing and i just cant strip it myself theres just to much paint and to many cracks and crevisies i sat in one spot with my anglegrinder ont he rear housing for about 1 minute before it hit metal there must be about 15 plus layers of rolled on paint its so thick that the paint is rough and bubbled up insted of smooth
Patrick Martin
02-25-2008 20:09:33
 Re: sandblasting price in reply to Pat-CT, 02-25-2008 13:43:55
Careful here..... ...
If you are doing this and masking certain areas off then cool but just dont start spraying it without covering joints, seals, ports, etc.
I'd be damn sure to wrap a rag around the axle where it comes out of the housing to protect the seal and keep sand out. Also the front main, PTO, steering knuckles, etc.
Roger46
02-25-2008 18:41:42
I would never sandblast an assembled tractor just to make it look pretty. If I wasn't taking the tractor apart, I would steam clean, use a good paint stripper, and then use the angle grinder with a wire brush. When you sandblast, that sand gets into many places you don't want it to. Any external seals, vent holes, moving parts that are greased (like the clutch shaft and brake shafts)will all have sand imbedded in them. I sandblast my tractors when I restore them, but only after disassembly and only parts that can be thoroughly cleaned afterward to remove any residual sand and parts that don't make any difference like rear wheels, brackets, etc. Roger
CNKS
02-25-2008 17:29:30
Use methylene chloride paint stripper. It may take 2 or 3 applications, but the excess paint will come off pretty fast. Finish with the angle grinder and various brushes on an electric drill. Don't know that I would trust a commercial sandblaster on assembled tractors, or myself either for that matter.
jim shoe
02-25-2008 14:18:50
Pat: A good rough estimate on a pro sandblast job would be approx. 250 - 350 for entire tractor. That is what the market is for a portable sandblast job here in central Indiana. That would turn your H into a nice white metal peice ready for paint! Good luck!!!
Vito
02-25-2008 14:00:43
Pat,
Don't know where you live in CT but I have a friend who does this for a living in Bloomfield.If you want his name and number email me.
Vito
HENRY E NC
02-26-2008 06:04:29
 Re: sandblasting price in reply to Vito, 02-25-2008 14:00:43
Here in extreme SW NC sandblasting goes for $80 per hour plus sand. I tried to sandblast my M and then took it to a professional and they prepare it at $80 per hour. So--best to get it all prepared(taped areas rags etc) before he does it . Takes around 2-3 hour depending on the paint. Henry
