Super C hydraulic block overhaul
riverbend
02-25-2008 16:02:09
I have several questions about rebuilding the hydraulic block on my Super C.
How do you get the check valves, bushings, and actuators out of the block ?
What does a 'drag link screwdriver' look like ?
In the Touch Control Serviceman's Handbook (GSS-1024) what are the circlip pliers used for ? It does not look like there are any C-clips.
There are several socket headed cap screws under the bottom cover. Should I take them out or leave them alone ? I don't see them listed on the exploded diagrams.
Many thanks
Greg
AndrewFromNS
02-25-2008 17:33:45
 Re: Super C hydraulic block overhaul in reply to riverbend, 02-25-2008 16:02:09
Did you have any trouble getting the Hydraulic Cylinder Head cover off yours? The one a friend and I are working on is being rather stubborn and uncooperative.
AR
riverbend
02-26-2008 05:18:38
 Re: Super C hydraulic block overhaul in reply to AndrewFromNS, 02-25-2008 17:33:45
No, I whacked it all over with a rubber hammer and tapped the edge of a thin putty knife about 1/8" into the gasket. After three or four places, it popped loose.
Idaho Ron
02-25-2008 17:12:13
Riverbend, What was going on with yous that you thought you needed to overhaul it? Ron
riverbend
02-25-2008 17:24:54
 Re: Super C hydraulic block overhaul in reply to Idaho Ron, 02-25-2008 17:12:13
I'm in the process of rebuilding the motor. Since it was all apart any way, I figured that I might as well go through the hydraulic pump and the block too.
Greg
VAJerry
02-25-2008 16:25:07
Blow compressed air into the different holes around the check valves etc, CAREFULLY. They will fly if you use too much pressure. A drag link screwdriver has a large bit and you strike it with a hammer to turn it. I did not need anything but common hand tools when I rebuilt the one on my Super A, which should be the same.
