WHEELS
F-400
02-25-2008 16:46:44
1943 H U KNOW THEY ARE TWO SLOTS ON AXLE THE CLAMP ITSELF HAS KEY MADE ON INSIDE TO FIT ONE SLOT ON AXLE. ON MY WHEEL THERE IS NOTHING THERE TO FIT SECOND SLOT.WAS THIS SUPPOSED TO BE MADE IN WHEEL OR WAS MADE LOOSE AND PUT IN SLOT BEFORE TIGHTEN UP THE CLAMP.ON MY 400 IT APPEARS THAT THE KEY IS SPOT WELDED TO WHEEL
Zach Bouchard
02-25-2008 19:42:12
 Re: WHEELS in reply to F-400, 02-25-2008 16:46:44
My 46 M has 2 slots in the axle. One key is on the hub and the other is on the clamp.
F-400
02-25-2008 17:28:30
WOULD U RUN TRACTOR WITH ONLY 1 KEY IN AXLES I USED PULL HANDLE TO ENSURE IT WAS TIGHT.MOSTLY USE H FOR BUSHHOGGING.I TRY HARD NEVER TO JERK TRACTOR.DON'T WANT TO HAVE TO FIND AXLE.
CNKS
02-25-2008 17:14:38
It's supposed to be in the wheel. At some point IH changed to a single slot that was wider, but it wasn't the H. That type is on my 460, don't know when the change occurred.
