FARMALL SUPER C
JD1783
02-25-2008 17:38:00
THE FARMER I WORK FOR HAS A 1952 MODEL WITH SERIAL NUMBER 135736, HE WANTS TO SELL. IT HAS NO PTO, GOOD REAR TIRES, FRONTS PROBABLY NEED TO BE REPLACED, DECENT PAINT (HAS BEEN REPAINTED AT SOME POINT) AND GOOD TIN, BEEN IN THE SHED FOR YEARS. HASN'T RUN SINCE?? WHAT IS THIS THING WORTH? LOCATED IN CENTRAL IL. THANKS - JOHN
Steven f/AZ
02-29-2008 04:31:05
 Re: FARMALL SUPER C in reply to JD1783, 02-25-2008 17:38:00
If the engine is loose, maybe up to $1000. If the engine is stuck, scrap price or $500 max.
leon
02-29-2008 04:08:42
Depends what you want to use it for. As a working tractor, the responses are probably OK. But if you're looking for a restorer, and if this tractor is very original and if the engine is not stuck, or better yet, if you can get it to run before buying, I think it would worth more in the range of $2000 in our area. NE Iowa.
Andy Motteberg
02-27-2008 15:53:58
I think $650 sound like a fair price.
Andy in ohio
02-25-2008 18:24:48
500.00 is a fair price.
