U 6 block
LN
02-25-2008 17:42:28
I have an M that I bought froze up, in the process of rebuilding and found that the block is cracked. I have a power unit off of a sawmill ID plate says it is a U6 bore is 3 7/8 will this block work in my M without modification, other than the visible differences ( has a dipstick ,and a fuel pump on the side ) Thanks for any input
Bob M
02-26-2008 08:55:36
 Re: U 6 block in reply to LN, 02-25-2008 17:42:28
I'm not 100% certain but I believe side frame clearance issues will prevent the original U6 starter from fitting when installed into an M tractor. Ie. you will need to use the original M starter with the transplanted engine.
Also unless the U6 and M flywheel/ring gear assemblies are not 100% identical I would recommend relocating the original M flywheel onto the transplanted U6 engine. (And if the U6 ring gear shows signs of wear now is the ideal time to install a new one - it'll be $40 well spent!)
MIKE FRENCH
02-25-2008 21:27:03
Same engine, should fit with no problems.
