Farmall M with Farmhand Hydraulics
DougN123
02-25-2008 18:46:50
I have a Farmall M with a Farmhand front loader It has its own reservoir and a PTO driven pump that has slow drips at the valves on the reservoir. Can I get help from someone on rebuilding this? I can live with this problem, but now I have a bad leak at the long cylinder going to the bucket. How do I fix this? Thanks. Doug
mkirsch
02-26-2008 04:52:19
 Re: Farmall M with Farmhand Hydraulics in reply to LMack, 02-25-2008 18:46:50
In a nutshell, you take it apart and replace seals, orings, or gaskets as appropriate. A local hydraulic shop can "rebuild" the cylinder for you, but basically they will do the same thing and charge you extra for the labor. Unless of course it's a welded cylinder, and then you're going to have to replace it I think.
Allan In NE
02-25-2008 19:01:10
 Re: Farmall M with Farmhand Hydraulics in reply to DougN123, 02-25-2008 18:46:50
Hi Doug,
Is it a F-11 or F-10?
Allan
DougN123
02-27-2008 05:47:36
 Re: Farmall M with Farmhand Hydraulics in reply to Allan In NE, 02-25-2008 19:01:10
Hi,
It's an F11. We're close to McCook, Nebraska. Where are you located. Thanks, Doug
