two point implements
Cornbinder
02-26-2008 13:26:41
In the local paper I have found a seven foot fast hitch harrow in good condition for $500 and a fast hitch plow for $400 do you guys think this is fair.
gene bender
02-27-2008 04:12:23
 Re: two point implements in reply to Cornbinder, 02-26-2008 13:26:41
If yoyu think you want them buy em remember they aint maken them no more and arent that easy to find in a lot of areas you could spend a lot of time and money driving around to find out someone has a piece of junk. buy em
gab
02-26-2008 17:44:24
I think a two bottom fast hitch plow should go for about $250 and if that's a tandem disc in good shape it might be a bargin at $500. Jim
Ksfarmmer
02-26-2008 17:11:09
Last fast hitch plow I looked at was a 2 bottom at an auction, I think I dropped out at about $100 to $150 which is about what I think it sold for. Don't recall fully but there was another auction for a 3 bottom that I think went for $300 to $350 to whoever bought the tractor. It's your money but those prices are steeper than what I might want to pay. I finally got a steel wheeled pull type plow for $65 that plows my garden just fine. If you have a good use for these maybe they are worth that to you. Sometimes people are pretty proud of two point implements.
Janicholson
02-26-2008 13:49:32
The harrow (Gang Disk) might be priced high if it has bad bearings in it. They can look OK but be worn to useless. Use a high lift jack to lift on the frame and measuer the journal wear. if they are ball bearings it should not have any more than a tiny bit of motion, If plain bearing journals, no more than an eighth inch of movement. If it is worn, it is $200 too high (opinion) JimN
James Williams
02-26-2008 13:38:15
Fast Hitch equ,is high in price,and worth what ever your willing to give
jimmy
