M clutch specs
1 Dollar
02-26-2008 13:26:46
I have my tractor split right now, so I want to know how to tell if the the clutch is 1/2 worn or not. I split it to get the block repaired, and I didn't drive it before, so I don't know how it functioned before.
Thanks
1 Dollar
02-26-2008 14:52:50
 Re: M clutch specs in reply to 1 Dollar, 02-26-2008 13:26:46
Its not to the rivets yet, and it doesn't have near as many either. It is probably within 1/8-1/16 of an inch to the rivets. If it isn't too expensive, I may just bite the bullet and do it.(but it really wasn't hard to split, even for a complete rookie)
BTW: got any good recommendations for dial calipers? Need to measure crankshaft journals while it is out.
Thanks again
ScottyHOMEy
02-26-2008 15:21:21
 Re: M clutch specs in reply to 1 Dollar, 02-26-2008 14:52:50
I like the Starrett's too.
Calipers aren't quite as accurate on a shaft like that as a micrometer, but not unacceptable. Just take several measurments at each point, remembering that you're looking for out of round as much as wear in the round.
1 Dollar
02-26-2008 16:50:04
 Re: M clutch specs in reply to ScottyHOMEy, 02-26-2008 15:21:21
How about a MITUTOYO, seem to still be a decent name, and a little less $$$. I honestly won't be using it much, that is why I want a caliper insted of a micrometer, it is a little more versatile.
ScottyHOMEy
02-26-2008 17:07:56
 Re: M clutch specs in reply to 1 Dollar, 02-26-2008 16:50:04
I hear ya on the versatile. Mitutoyo's a good name, too.
glennster
02-26-2008 15:04:59
if you've got an 1/8 to the rivets you should be fine. the new disk has around 1/8-3/16 meat before the rivets. if you ever need to you can do the clutch thru the belly pump hole. for a dial caliper, i like the starretts, here is a link
glennster
02-26-2008 13:50:19
wow, you're in luck, just happen to have a brand new disk under my desk for my super m. disk measures 3/8 inch thick new. you should still have some meat left on the linings before the rivets. if not, replace it. heres some pics. pics are fun!!!!
third party image
third party image
third party image
