340 Utility w/ diesel motor wont run
Lyle R.
02-26-2008 17:39:45
I have a 340 utility diesel and my grandfather did a rebuild on the motor and now it will not start and would like to know what the timing specs are and where #1 piston needs to be to set timing gears to function properly. Any help will be appreciated.
Lyle R.
02-28-2008 11:35:02
 Re: 340 Utility w/ diesel motor wont run in reply to Lyle R., 02-26-2008 17:39:45
Thanks for the help
1fortyfanatic
02-26-2008 19:22:55
 Re: 340 Utility w/ diesel motor wont run in reply to GordoSD, 02-26-2008 17:39:45
Hey, sorry you're having problems. Unless someone pipes up here with all the specs you'll need, looks like you need to buy a manual for that thing. You can probably find a copy somewhere on this site. Like the top left column where it says tractor manuals. But on most timing issues on any engine, #1 needs to be TDC and there is usually a mark on the crank pulley, and there is usually a corresponding mark on the cam. Never worked on diesels though, so I could be wrong.
Also on the left, down a ways, there is a link marked "Tune up specs", you'll probably be wanting those at some point assuming that they cover your tractor. Good luck!
Dave
