MikeCA, no go on parts
GeneMO
02-26-2008 18:53:28
Mike, The brace you needed for the drawbar is more welded up on my parts tractor than the one you have.
Got to looking for the generator bracket and couldn't find it, then looked where the starter would be and there was a cover plate bolted on. This ole H had no lights, starter, hence no generator.
sorry I couldn't help you. Keep asking though.
Gene
Mike CA
02-27-2008 07:22:20
 Re: MikeCA, no go on parts in reply to Damp;Dservice, 02-26-2008 18:53:28
GordoSD said: (quoted from post at 08:05:25 02/27/08) I have a generator bracket. And I have one of those support rods that goes from the vertical bracket to the horizontal bar. The one you loosen and change holes to adjust the height. Is that what you need?
Gordo
Yup, sure is. I'll double check the generator bracket. I think what I have is shop made. I know the bolts aren't original, which is what caught my attention. And I'll be changing the generator to a 12v eventually, so I figured I might as well get the whole bracket correct.
The drawbar... square, I guess you call it... is "bent" up on the left side as you look at it. When I did a closer inspection I found out that the left diagnal support bar had been welded. So my guess is that it was welded a little shot, and it pulling that side of the drawbar square up a little too much.
I know I'm picky. I own one tractor, so I want it as perfect as I can get it, and afford. :lol:
old
02-26-2008 21:26:53
 Re: MikeCA, no go on parts in reply to GeneMO, 02-26-2008 18:53:28
Gene. Kick me an e-mail and give me your phone number. I'll be in Columbia on the 4th amd maybe I could stop by on my way home. It would take me the long way but what the heck you have been here so maybe I can be there. LOL
Mike CA
02-26-2008 20:37:10
Sure Mike, e-mail me and we can talk.
weare (dot) mikenjen (at) sbcglobal (dot) net
Thanks!
Where are you located? Hopefully California! :lol:
MIKE FRENCH
02-26-2008 20:18:24
If you need H farmal parts, let me know have several. Gene you should know that as you were here once, email me. Thanks Mike
Mike CA
02-26-2008 20:04:27
 Re: MikeCA, no go on parts in reply to migraine, 02-26-2008 18:53:28
GeneMO said: (quoted from post at 19:53:28 02/26/08) Mike, The brace you needed for the drawbar is more welded up on my parts tractor than the one you have.
Gene
Thanks for looking. How did you know I was on watch tonight and couldn't check my e-mail? :lol:
I'll be heading to the salvage yard real soon to pick up Andy in OH up his SH stage II grill and my front pedestal. I'll be looking for a smatering of other parts as well. Mainly a cut-off switch so I can start re-wiring.
I'll keep you posted.
GordoSD
02-27-2008 07:05:25
 Re: MikeCA, no go on parts in reply to Mike CA, 02-26-2008 20:04:27
Gordo
