1066 muffler and tach
allnightshifter2
02-26-2008 23:18:20
I"ve just invested in a 1972 1066, It has straight pipe without a muffler. I"ve heard that gassers like a little back pressure that a muffler gives; is this also true with turbo diesels? Got plenty of HP for what I need, just would like to know what is better for the motor. Also at full throttle tach only goes up to a little under pto speed, could this be the tach gears slipping or cable? It's showing 8900 hours on it.
Thanks John K
Janicholson
02-27-2008 16:18:52
 Re: 1066 muffler and tach in reply to allnightshifter2, 02-26-2008 23:18:20
As Allan indicates the tach night not be bad if it is not looking squirrelly. rent or borrow a strobe tach to check actual engine RPM. (they do not connect to anything, just have a dial to make the front pulley appear to stop) with a readout of rpm. JimN
Steven f/AZ
02-27-2008 06:08:40
We straight-piped our 1086 several years ago... EGT runs lower, better fuel economy on light loads and it sounds sweet at 5 on a clear morning you can hear it bellar from several miles away!
the Unforgiven
02-27-2008 05:36:40
No benefit for the engine to have a muffler, many turbo applications do not. I eliminated the muffler on my 1086, inside the cab you can not tell the difference. Outside it makes a lot more whistle and sounds more throaty in the mid-rpm range, but as far as noise there is virtually no difference.
Randy in NE
02-27-2008 04:54:33
There are many, many turbo diesels of every color out there running with straight pipes. If you have a cab then that will quiet it down a little. If you are going to do a lot of farming with it you should probably either put a muffler on it or wear hearing protection. I know. Most farmers don't worry about things like that. They do sound sweet with the straight pipe. I would agree with Allen on the tach. If you haven't been around a lot of turbo diesels it is hard to tell from the sound if you are getting all of your rpms.
Allan In NE
02-27-2008 03:05:27
Good fer you, John!
Don't think the straight pipe actually "hurts" anything, but it sure makes 'em sound gawd-awful. A new muffler and extension is almost as good as a new paint job. :>)
That tach works just like the old cable-driven speed-o-meters used to. If it is not jumping or bouncing around, think the clock spring bushings are gummed up with dirt/oil and you probably need a new head.
Is the engine actually coming up to speed as it should?
Allan
