M Farmal
Mike L
02-27-2008 04:28:29
1952 M 12" clutch Do I have to split the tractor to remove the clutch shaft. Tractor needs seals and pilot bearing
Andy Motteberg
02-27-2008 15:40:30
 Re: M Farmal in reply to Mike L, 02-27-2008 04:28:29
Yes, you'll need to split the tractor.
NDS
02-27-2008 06:18:02
The clutch disk ONLY will come out bottom and you should be able to get to pilot bearing and trans. seal. They are like a Chinese puzzle to get back in and it may be easier to slit tractor if you have equipment. Have seen this done several times but last time I tried I gave up and had old IH mechanic put it back together.
NDS
02-27-2008 06:21:57
 Re: M Farmal in reply to NDS, 02-27-2008 06:18:02
I was working on Super M and assume 12 inch M will be the same never worked on one though.
Rootsy
02-27-2008 05:25:05
 Re: M Farmal in reply to glennster, 02-27-2008 04:28:29
Are you saying you need to replace the seals on the front of the transmission (input shaft and counter shaft - ie lift all pump shaft)?
If so you DO NOT need to split the tractor to replace them. Did mine last winter without much issue.
Mike L
02-27-2008 17:02:45
 Re: M Farmal in reply to Rootsy, 02-27-2008 05:25:05
Yes the seal in the countershaft is shot!!!!!
and while im at it might as well replace the pilot bearing the tractor jumps ot of road gear
i was told that may be the cause
i can almost get the countershaft coupler off
its just so close but wont happen unless i remove the clutch shaft
dej(jed)
02-27-2008 05:04:17
Yes-You need to split the tractor.
