Update on #3 plug not firing.
unioncree
02-27-2008 06:17:38
Well the problems seems to self corrected itself. I took off work a little early to fix it, since this type of thing bugs me until it's fixed. It was raining slightly so I decided to put the tractor in the barn, it started right up and ran fine, #3 plug was firing.
I wish I had found the problem since it will be in the back of my mind that the problem could pop up when I'm haying.
Thanks for all the advise.
Bob
1fortyfanatic
02-27-2008 10:16:53
 Re: Update on #3 plug not firing. in reply to Richard Wurtzberger, 02-27-2008 06:17:38
That's the fun of our addiction. Little surprises and mysteries. Good for you.
Dave
kippster
02-27-2008 09:30:28
 Re: Update on #3 plug not firing. in reply to unioncree, 02-27-2008 06:17:38
Glad to hear that you got her fixed. Its always frustrating when you can't figure something out, but it's always a great feeling of accomplishment when you finally get it right. Good for you.
unioncreek
02-27-2008 08:02:55
I'm going to stop and get a new set of plugs for it just to eliminate that part of it.
Bob
Jerry Gilliam
02-27-2008 07:26:01
The more easy way to check for a firing problem on a plug is to remove plug wire and attach another plug to wire. Ground plug to tractor and see if that plug is firing outside the cyl. If it is getting fire and you see a good blue/yellow streak popping inside the plug tip, then you will have fire delivery when you reattach to that plug screwed into the #3 head.
Jerry
Janicholson
02-27-2008 06:25:11
I firmly believe it was the plug itself. I was just re reading all the posts on it and am pretty convinced it is a shorted plug (there have been several additions to that post). Take a plug with you (and wrench) so that if it does it again it can be substituted. JimN
