200 grill
KEITH SHAW
02-27-2008 12:23:08
hello, i was looking at a 200 farmall grill shell on ebay and was wanting to find out if the 200 grill shell would be the same as a 130 farmall thanks keith
dagecr
02-28-2008 13:53:24
 Re: 200 grill in reply to KEITH SHAW, 02-27-2008 12:23:08
The 100 / 130 grille shell is different from the 200 / 230, they are cut different at the bottom where they fit against the steering housing but they can be interchanged & most people will not notice.
Andy Motteberg
02-27-2008 16:47:59
They are the same.
Randy in NE
02-27-2008 14:14:57
The inserts for the 100/130 and the 200/230 are the same, 362592R11. The shell for the radiator/grill for the 100/130 is 362584R91 while the 200/230 is 362586R91. They may be close enough that you will have a satisfactory fit.
Andrew Z
02-27-2008 12:28:49
Yes they are the same 100 130 200 230 all the same.
Andrew
