Farmall M input shaft
The Farmall
02-27-2008 17:46:22
I have a SMTA that I am taking the TA out of and need to find a new longer input shaft to make up the difference.
going to use the 12 inch clutch but need to beef it up a little also for tractor pulling.
Anybody know of any aftermarket dealers or any other models that will bolt in for this conversion?
Thanks. Ryan
MN Dave 2
02-28-2008 04:35:11
 Re: Farmall M input shaft in reply to The Farmall, 02-27-2008 17:46:22
Leave it in, you'll do a lot better with it in for pulling!
MIKE FRENCH
02-27-2008 19:58:34
If taking the TA out you will need a TA eleminator kit, they go right in were the TA is with no modifications and use your old input shaft. I would rebuild the TA with a sprag kit instead of the ramp and roller set up, Steel Wheel Ranch can get you the parts you need either way.
