Improvements from 786-886 to 3088-3288
Trent544
02-27-2008 17:56:40
What changes or improvements were there from the smaller 86 series to the 88 series? Anything that was not as good on the 88's?
mkirsch
02-28-2008 05:40:02
 Re: Improvements from 786-886 to 3088-3288 in reply to Paul G. in Mn, 02-27-2008 17:56:40
Trent,
The 86 series isn't "smaller." After you remove the hoods, the tractors are almost identical. Same engines. Same frames. Same transmissions. Same cabs.
Trent544
02-29-2008 00:46:02
 Re: Improvements from 786-886 to 3088-3288 in reply to mkirsch, 02-28-2008 05:40:02
I should have explained better, I meant smaller 86 series as opposed to larger 86 series such as 1086, 1486.
Allan In NE
02-28-2008 05:51:43
Whadda think they were thinking on that retarded cooling system air flow? Just handwritting on the wall? :>)
Allan
IaGary
02-27-2008 19:00:29
 Re: Improvements from 786-886 to 3088-3288 in reply to Trent544, 02-27-2008 17:56:40
The transmission was upgraded for easier shifting other than that I don't believe there were to many changes.
Gary
