M loader
jjamna
02-27-2008 18:54:19
What is a loader for a M Farmall worth? I am going to look at a couple tomorrow or Fri and he ask me what I would give. I am thinking I have seen them from $150 to $400 but can"t remember for sure (the older I get the worse it gets)
jjamna
02-28-2008 13:18:39
 Re: M loader in reply to jjamna, 02-27-2008 18:54:19
I think I am going to get it. Still don't know what kind it is but it has everything I need to put it on the tractor. Only one very light welded place. and can get it for $300
Farmall guy
02-28-2008 11:11:34
it depends on the condition its in if its rough shape its probable worth about 50 dollars but if its in decent shape and it works well it can be worth as much as 350 to 400 dollars.
dhermesc
02-28-2008 09:56:56
I paid $200 for an old Farmall 33 loader with a trip bucket a couple years ago. First thing I had to do was have one cylinder rebuilt though.
Here's a picture of one on an H.
http://www.tractorshed.com/contents/tpic10571.htm
jjamna
03-05-2008 21:45:17
 Re: M loader in reply to dhermesc, 02-28-2008 09:56:56
Where do you get the parts to Rebuild it?
jjamna
02-28-2008 11:07:44
Thanks You are the only one to give me a $ amount
gene bender
02-28-2008 03:33:43
Many companies made loaders for the M. Most didnt need another pump as the belley one worked just fine on a regular model. Some were easier than others for putting on and removing. What weight do you plan on lifting.
jjamna
02-28-2008 07:09:53
 Re: M loader in reply to gene bender, 02-28-2008 03:33:43
just loading manure mainly
Scott in SF
02-27-2008 22:52:34
Most M's that had loaders had Farmhand F10 or F11's. Both are good but kinda getting old. If you buy it make sure you get the pto pump and the control valves. And like others said check out the welds, the buckets and if it has a grapple fork .
Andy Motteberg
02-27-2008 19:13:17
What kind of loader? What model? Is it in good shape? Any welds or repairs? What kind of buckets/or forks does it have?
jjamna
02-27-2008 20:24:16
 Re: M loader in reply to Andy Motteberg, 02-27-2008 19:13:17
I have no Idea. He just said he had two of them.
