Transmission Oil Fill
Bud W
02-28-2008 15:02:22
Is there a special wrench to remove the fill plug on the operator platform? The square hole is much larger than a 1/2 inch socket and I can't figure what else I can use although it must be pretty simple.Thanks
bc
02-28-2008 20:51:39
 Re: Transmission Oil Fill in reply to Bud W, 02-28-2008 15:02:22
I have a piece of square bar to stick in there. It is technically 1" bar but it is ground down on 2 sides to fit in. You may be able to stick the jaws of some channellocks or pliers and wedge them in then turn them.
glennster
02-28-2008 17:48:47
its 3/4 drive, you can either pick up a 1/2 to 3/4 drive adapter and use your 1/2 inch breaker bar or rachet or....pick up a 3/4 drive breaker bar from farm and fleet, tsc, orschelns, big r's....you dont need a snap on or matco one to get the plug out.
1fortyfanatic
02-28-2008 17:48:16
 Re: Transmission Oil Fill in reply to Wesley Stephens, 02-28-2008 15:02:22
On my 140, it was just a socket extension, 3/4 inch drive I believe. Good Luck
DAve
scott rukke
02-28-2008 16:49:16
I used channel locks on mine but there was about 3/4" sticking out above the platform.
CobraJay
02-28-2008 16:26:51
Sounds like it might be 3/4" drive.
