PTO to drawbar specs....
Clefus
02-28-2008 16:12:02
I was reading the M 3 pt hitch post ... got me thinking..
My 560 has a FH drawbar without the swinging tongue attached to the front of the hitch...but there is a plate bolted to the drawbar extending the hitch pin hole back about 4 inches...Took it off to paint the tractor but wondering about leaving it off...
My baler hooks up fine as does the woods mower....
But on the C the Woods mower wont work ... PTO shaft too long....or really drawbar not extended enough...
What is the spec'd distance for implements?? is it measured from the end of the pto shaft??
Clefus
02-29-2008 16:00:13
 Re: PTO to drawbar specs.... in reply to Clefus, 02-28-2008 16:12:02
thanks roger
Clefus
02-28-2008 18:25:27
karl
the plate was a home made one....I will make a new one or make a tongue.....
karl f
02-28-2008 17:29:29
 Re: PTO to drawbar specs.... in reply to Steven f/AZ, 02-28-2008 16:12:02
Clefus said: (quoted from post at 17:12:02 02/28/08) I was reading the M 3 pt hitch post ... got me thinking..
My 560 has a FH drawbar without the swinging tongue attached to the front of the hitch...but there is a plate bolted to the drawbar extending the hitch pin hole back about 4 inches...?
that plate was made by IH for the purpose of making the PTO dimension correct. There are many home brew models out there, and some mower attatchment ones that look similar as well. best to measure yours and see if it gives right dimension.
karl f
Roger in Iowa
02-28-2008 16:20:49
Specs are:
540 rpm shaft= From end of shaft to center of hitch pin hole is 14"
1000 rpm 1 3/8" = 16" from end of shaft to center of hitch pin hole.
1000 rpm 1 3/4" = 20" from end of shaft to center of hitch pin hole.
Regards,
Roger in Iowa
