Farmall C lift arms
Johnny D
02-28-2008 21:46:52
Are all three lift arms suppose to line up with each other? I had the hydrolic block rebuilt and now the two lift arms on the left side do not line up with the levers locked together. If so can they be adjusted using the stop control settings on the hydrolic block. Or perhaps there are other suggestions.
gene bender
02-29-2008 03:27:00
 Re: Farmall C lift arms in reply to Johnny D, 02-28-2008 21:46:52
Yes you need line up the stops under the unit.
