H high idle speed - solved. Thanks
Alan Martinson
02-29-2008 14:50:05
Thanks to all of you who gave me tips on this high idle speed problem. I think it was a combination of things. I was a bit more careful putting the gov. throttle shaft into the carb. but I still could not get it to idle slow. I eventually followed governor adj. directions from the manual (and sent via email by Wayne). I had to adjust the low idle stop screw on the gov. control lever. and that allowed the throttle shaft to turn more - closing the carb. butterfly further. It works good now. I suppose I moved something when I removed the carb to install the new manifold. Thanks guys.
Brownie450
03-01-2008 03:00:51
 Re: H high idle speed - solved. Thanks in reply to Alan Martinson, 02-29-2008 14:50:05
Thanks to you for letting the folks here know how it came out. Most people never feed back how things turned out.
