200 distributor problem
ny bill o
02-29-2008 15:39:57
my 200 won"t start. it has new points and condensor that are set and working properly. in following the step by step from john t posted 12-28-07, i found the coil to distributor wire goes dead when the nut on the post through the side of the distributor is tightened. i took the post off, and can"t see any cracks in the bakelite? , but it definitely kills the electricity. any suggestions short of buying a whole distributor? thanks.
Chad Hurta
03-02-2008 06:21:44
 Re: 200 distributor problem in reply to ny bill o, 02-29-2008 15:39:57
Mine had the same problem and for a temporary fix I wrapped the post with teflon tape and then reinstalled and has been working for a year now so I have left it alone.
chad
NDS
02-29-2008 18:10:15
Shorts in that area are common problem, insulators and post were still available last time I checked so that area can be made "like new". If your local dealer does not want to get them I bet Bermuda Ken at cngco.com will.
