Re: Farmall H lift-all system?
tigfarm06
02-29-2008 19:39:19
SD FARMALL said: (quoted from post at 06:39:58 01/26/08) That's what I figured, and I'm going to replumb it into the bottom.
Thanks Scott,
Eric
I am curious to find out if rerouting the return line to the bottom of the pump fixes the vent cap leaking issue? I've got the same issue with a Super H, which as far as I know was operated for years with the return line connected to a T in the vent cap port.
akb
03-01-2008 00:04:22
 Re: Farmall H lift-all system? in reply to tigfarm06, 02-29-2008 19:39:19
Yes plumb ihto drain hole.
Scott Rukke
02-29-2008 19:46:58
Routed mine to the bottom and have no cap leaks whatsoever.
