Letter Series Ammeters
GordoSD
02-29-2008 20:00:33
I just pulled the ammeter out of my 49 H. Stripped a lot of paint off and found the bezel is brass. Polished it up with a Dremel and Brasso, and it looks like GOLD. It has the IH logo and the number 423 (8 or6)3-DA underneath Now when you lay the gauge on it's side the needle will slowly rise to about 6 amps. Lay it on it's other side and same thing, -6 amps. Is this normal? All the repro gauges are nickel/chrome. When did IH switch from brass to chrome bezels?Or were the old gauges chrome plated over the brass? This will drive the correct police crazy Gordo
Sam#3
03-01-2008 07:39:25
 Re: Letter Series Ammeters in reply to GordoSD, 02-29-2008 20:00:33
Lots of things used to be made of brass. Then the money issue came along.... As far as the needle position ammeters are somewhat delicate in their manufacture and useage. The needle is heavy enough to turn against the spring tension.
r4etired
03-01-2008 07:16:59
Guages were a vendor item for IH, I would bet during the production run of the letter series several mfgs were used.If I remember correctly there were 3 face changes on the amp guage.
gene bender
03-01-2008 04:02:05
I have found several that were brass when i replaced the glass and cleaned the face
GordoSD
03-02-2008 11:12:04
 Re: Letter Series Ammeters in reply to gene bender, 03-01-2008 04:02:05
Please start a new thread and tell us how to disassemble and gauge and clean the face
Gordo
Brownie450
03-01-2008 03:55:28
Wondering if they didn't make the rims from brass for rust/corrosion protection??
kfox
03-01-2008 04:41:22
 Re: Letter Series Ammeters in reply to Brownie450, 03-01-2008 03:55:28
I believe the brass rims were painted black. ken
