Farmall SM battery box problems
Mark Carey
03-01-2008 20:57:46
I bought a battery box for my 1953 super m and from what I understand its a stage 1 tractor so the box goes under the gas tank. thats where the battery was when I bought the tractor but the box was missing. I bought a box but it doesnt seem to line up with anything to bolt down.could i be missing somthing? thanks
Mark Carey
03-02-2008 06:53:44
 Re: Farmall SM battery box problems in reply to Mark Carey, 03-01-2008 20:57:46
Thanks everyone youve cleared up alot and I appreciate it. At least now im not standing around scrathing my head anymore wondering whats wrong!
TractormanNC
03-02-2008 04:31:13
You beat me D.
TractormanNC
03-02-2008 04:29:47
There is supposed to be a strap about 1 inch wide and about 12 inches long on top of the transmission cover that the battery box bolts to with two 3/8 in bolts. Many times these have been removed and thrown away and the bolt holes have filled up with crud. Also the battery box should have two slots in the bottom which slide on two special bolts that screw into the trans cover. HTH.
D Slater
03-02-2008 04:25:24
The box should have 2 slotes that go onto 2 special bolts with big heads that screw into top cover. They are used to slide box back and forth when accessing battery. What holds box is a steel strap that bolts under middle of box crosswise using 2 bolts into transmission cover housing. Its around 3/16 thick by 1 or 1-1/4 wide with bolt holes in each end to line up with battery box holes. It bolts on before box is installed.
james rumph
03-02-2008 04:06:19
Dumb question are you sure that it doesnt go under the seat like my 52? Meaning they sent the wrong box.
Mark Carey
03-02-2008 06:51:59
 Re: Farmall SM battery box problems in reply to james rumph, 03-02-2008 04:06:19
yeah Im pretty sure it goes under the tank. All stage 1 super m's were under the tank. not a stupid question though, any help is great help I appreciate it.
